Problem with Gauges
MoNsEclipse
Dec 2, 2004
Salinas, California
I installed me 3 gauges today, (A/F, Boost and Water temp) on my 98 eclipse gst. When I was finished it seemed like my car ran great and all the gauges worked. When i stoped at the stop light my RPM's went to 0 and my car shut off. The Check Engine* Light soon came on. Now whenever I stop my car it gets close to shutting off or shuts off completely. The only thing i could think of is that I fried the o2 sensor or somthing. Can someone help me with this. What do you guys think it is??
you're BLISS screw maybe out of adjustment a bit, try unscrewing it about a half a turn to a whole turn which is Lefty Losey let me know. -Matt
sounds kinda like my car did when i forgot to plug up a hole in the intake to the turbo. so i would say check for a major boost leak
When installing the gauges did you disconnect the battery? Mine did something similar when I installed mine and come to find out i didnt tighten down the terminal enough and it had a bad connection. Check that! :thumb: :talon:
