Problem with Dejon Tool MBC-2a
xxREVERBxx
Jan 28, 2005
Stockton, California
I recently installed a Dejon Tool MBC-2a. For those who don't don't its a Lo-Hi dual stage boost controller. The MBC isn't working at stock level or on what ever setting I choose. I flick the switch and can hear a clicking noise from the MBC. So I think its working properly. The boost shoots past 11psi and gone as high as 18, maybe higher if i din't let off the gas. i installed it per Dejon Tools instructions and Im hoping im not missing anything.
For those of you who have this MBC, have you had this problem? Any connections I should check?
Anymore info needed?
Thanks for the help guys.
~Franklin
I got this BC on order,...I'll update how it works out. Good thing is I just realized there shop is about 45minutes from me, If I have problems I'll run over there and see whats the matter. SOunds like your problems are installed incorrectly or the ball is sticking, not releasing the air.
