dejon tool mbc 2a
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
ok i know how to wire it up and everything but i was alittle stumped on which way is up for the switch. which way will flip it ON."set boost level" and OFF to stock boost level. on the switch there are 2 terminals which are positioned more towards the bottom. is this the OFF part or what?
help me out here!!!
On a switch the off side is the side that has no terminal. That way when you switch it on the two terminals on the other side are then connected. I also have a question about this Boost controller: does work properly because i have seen two other people on this board saying something about it not limiting the boost?
