Problem diagnosis
Smash_NDash
52
Jun 11, 2011
charlotte, North Carolina
Lately I have been lean surging REALLY bad in about the 2k-3.5k range while driving.
I have three check engine light codes:
12= power disconnected from ecu in last 50 cycles
31= Evap solenoid circuit
51= Lean fuel system
I know the 12 is appearing because my ecu seems to be crapping out, but what would be a cause of 31 & 51 appearing at the same time.
My guess is that when I got my car rebuilt it was sitting with about 1/8 tank of gas for about 6 months. I picked up the car in february 2012 and have been driving it ever since. Recently I have been driving my car all the way down to the E line on my fuel gauge. So I am assuming I have gotten a good bit of bad gas in my fuel system and my fuel filter might need a change.
My second guess would be an 02 sensor?
Third would be a bad MAP?
I have money to fix the problem, but I do not have money to just throw parts at it so any help on testing for specific problems would be greatly appreciated.
with this being said i would be hesitant to start trying to fix electrical issues. I would get a rebuild or a known good ecu and see how things go.
if the ecu capacitors are leaking it could short out all kinds of stuff and cause unknown issues to pop up.
for code 31 you could have a bad purge solenoid . for code 51 you have to check fuel pressure also check for vacuum leaks .
  • Wanted 6 bolt NT water pipe
    • chrisman287
