Primary Ignition Coil @ 2.1 & 2.0 Ohms....
Artago
2,094
31
Nov 30, 2006
North Vancouver, BC, Canada
Hi all. I measured my Ignition Coil because I have a P0300 code. Here are the readings:
Primary Coil Resistance:
2.0 Ohms
2.1 Ohms
Secondary Coil Resistance:
12.1K Ohms
12.0K Ohms
So it looks like my primary coil is out of spec.
My question:
Can you replace (or repair) the primary coil only? Or do I have to replace the whole coil pack? Is it possible to order just the primary coil? And if so, where can I buy it?
If not where can I buy the ignition coil pack at a good price?
Thanks,
Tomas.
Thanks, I'll try that. So I just need to replace the Primary coil pack and not the secondary ... right?
I've had the same code now for around 2 years. It comes only when cruising over 70 for like 30 min or longer. I ohm'd out the coil similar as you but doubt its the culprit. I've heard that having an aftermarket flywheel can cause this code to... Thats about when I started getting it was when I upgraded clutch and flywheel. I would just think that these primary coils would go out of spec way more than that to cause a problem or just fail all together. I'm begining to think this is just a "phantom" code caused by the new flywheel and there really is not a misfire at all. Let me know what you figure out.
