pressure plate bolts?
oztofrdm
211
Oct 27, 2004
Wilmington, North Carolina
hey i was looking in the service manual and everywhere else, and i couldnt find the specs on the bolts. can someone please help me out. By the way this would be for a 1g gsx with the 6bolt
Torque spec's?
25 foot-pounds, and be careful, any more than that will break those bolts off.
Jay
sorry i was asking what size bolts they where so i could buy new ones, i figured since i have spent so much money on the other components why use the stock bolts with 100k on them
Thank you SO much. its the act streetlight, so do i need the 20mm
You're welcome. The ACT flywheel is steel, so the stock length will be fine. Don't forget new lockwashers and loctite.
pneumo said:
8x1.25 16mm long. Or if you have an aluminum flywheel, use 20mm long bolts.
Are these the same for the 2G? I'm doing an AT>MT swap and need these bolts. I'm using a stock galant flywheel on my spyder. Thanks..
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
