- Thread starter
- #26
pauleyman
DSM Wiseman
- 11,420
- 5,314
- Nov 19, 2011
oklahoma city,
Oklahoma
This will be a long read.
Car is back on the ground. I'll share my experience and keep in mind this is not my first bushing job. I've done like 4 on different cars. Here are some observations. This is for a 2g using Energy Suspension bushings. I've done a full front bushing on my other 2g using ES bushings and it was no big deal. I used the hole saw method above and I've previously used drilled holes, burning etc. Hole saw is THE way to go. To cut the shell do not use a hack saw. I had trouble because the blade bows up and you only end up cutting the outer edges of the shell. Sawzall fixed that. Be careful or you will cut into the control arm/knuckle very easily. On to the meat and potatoes.
The upper bushing on the knuckle was in and out. The farthest one out on the bottom was the same. The bushing closest the center of the wheel bearing was where problems started. I got the bushing and shell out no problem but the new one would just not press in. I'm aware the one side of the hole is beveled and the other isn't so I beveled the other side. No dice. It's too awkward to put on the hydraulic press so I used the bench vice like I did the other two and that didn't touch it. I resorted to a piece of all thread and some washers. It finally went in....so I thought. I got it through easily but the last little bit just would not go. I said screw it it's close enough and went to put the sleeve in and it wasn't going. The lip was still in the knuckle a little bit. Quite enough to keep the sleeve out. I damaged the sleeve with a hammer trying to get it in. I finally decided to remove it and try again. What a mistake. The only way to get it out was to destroy it so I did. This time I didn't even bother with a new one as is. I split the bushing like a prothane kit. The problems don't end here. I noticed why I think it didn't go. The knuckle sleeve isn't symmetrical. One side the tube was a little beveled and not perpendicular to the bushing. I don't think the bushing could go through no matter what. This proved to cause additional problem with a split bushing. I immediately noticed the sleeve didn't sit flush with the two halves. As I predicted it didn't want to go into the control arm. After 10 min or so I said screw it and tweaked the arm opening a little knowing the bolt would squeeze down on the sleeve on reassembly. The rest of the job went normally with the exception of some cussing at WHY did they have a separate parking brake. I haven't done shoes in a long long LOOOOONG time. Anyway it's time for a test drive.
