Power Windows and HVAC do not work!
swarm
DSMtuners Server Guru
466
Mar 26, 2004
Spokane, Washington
I did search.
Got a '92 Eclipse GSX the other night, and while on the test drive, everything worked. It rained and since then the Power Windows and HVAC controls do not work. Map lights work, Radio works, everything else works. I checked the WDO Relay, I checked the Alternator Fuse. Still nothing. I took the door panel off the driver side and ensured that the connector did not come unplugged..
Any ideas?
Does anyone have any other ideas as to what would cause this? Anything I should check? I need the fan controls to work, it will snow here soon - the reason I got the car.
as said above check all your fuses in side the car and engine compartment with a fuse light! hvac = heating ventilation and a/c:talon:
