Power window operation without key for 2g
Tired of always having to turn the ignition key on to operate your power windows?
Replacing the power window relay with a 14 gauge jumper will allow this and you don't even need the key in the ignition. The circuit will still be protected by the 30A power window fuse. The relay is up under the driver's side dash. Just replace the relay with the red jumper wire shown here. Solder or crimp (solder preferred) a spade lug on the jumper ends and it will fit in the relay socket snuggly.
