power steering removal
99 gst spyder
522
Jul 12, 2007
st. paul, Minnesota
i took everything out even the two lines going to the rack. is it okay to just capp both the hole on the rack or should i route them together with a short hose. now i have it capped off. will there be anything wrong capping them?
thanks in advance guys.
one thing too, i also did a timing belt change myself according to the vfaq and was wondering if there a way to double check if all the installations are correct.
i was thinking that i should tdc it and make sure all the timing marks are align. if they are all align, i should be good right. i've been driving for a bit now putting about close to 100 miles on it.
thanks again.
I would loop them with a short hose, it will turn a little easier as it's not fighting the pressure. If you followed the VFAQ on the timing belt change than you should be fine.
thanks alot for the fast reply. i'll check vfaq if i can find anything.
one other thing that i forgot to mention. i have ksports on the car when i bought it. every time i hit a pot hole small or big, seems like the strut likes to hit the frame likes it's out. just the driver side only though.
I did mine and can't tell you how it'll work yet, as I've not finished with my rebuild. here's a pic' of what mine's looks like.
