Resolved Power steering O-ring failure
BLACK'98DSM
Moderator
5,491
3,001
Feb 9, 2019
Alabama
I just replaced my power steering pump, since the last had a ton of shaft play. When switching parts over to the new pump everything went smoothly except one piece. For some reason I can't get the piece to go all the way in. And it keeps breaking o-rings. I have tried 3 times. I tried tapping it in lightly with a hammer, pushing it in with my hands and fingers, and twisting it back and forth. When I tapped it with a hammer it broke the o-ring. When I squeezed in with my hands the o-ring broke. And when i twisted it in the o-ring did not break but I think it is cracked or not seated properly, because after less than 2 minutes it leaked all my fluid out in the driveway and garage.
All 3 o-rings were different brands and quality. I lubricated them before attempting to install. They are the same size as the one I took off.
What am I doing wrong? Or what is going wrong?
^This is not my pump, it is just an image I got from Google to show you the part I am talking about.
I bought a new pump. Only thing I'm having trouble with is that single o-ring. It won't snap in properly and seal. I was wondering if anyone had any tricks or tips on how to do this?
So you’re having issues putting the hard line onto the yellow circled, correct?
No. This one:
It is for the hose that goes straight from the reservoir to the pump.
But you were able to get it in by twisting and it still leaked? Is that right?
Yes, but I pulled it back out to inspect and the o-ring was broken. I'm having trouble putting it in, it is super tight and the best I have done without breaking it is putting it in crooked.
I would just re-use the one from the old pump since it didn't leak or break but like an idiot I said "oh its old" and threw it in the trash LOL
The pressure should be low on that hose, so perhaps if all else fails try gasket maker? Not a good permanent solution but gets it running perhaps. It shouldn't be that hard to make this work, and the o-ring does sound too big and is pooching out and getting pinched off as you tighten. You should be placing in on the tubing, and seating it into the recess, not the other way round (at least, that's how these are arranged on a 1g pump like mine.) I took the return fitting off my pump and put it back on with the old ring, and no problems yet (now I've jinxed it!, damn.) As far as getting the right o-ring, look in the factory parts catalog or an online one like Amayama.com, and see if they call out the I.D. in mm. I was able to do this for an o-ring on my new rack for my car. It came with two O-rings of the same size, but he pressure (supply) is only supposed to be 6mm, while the return is 7.5mm. They had one at my local NAPA. I had looked at a company that lists many rebuild kits on ebay called power steering seals, so perhaps they can get you the right size. send a photo of the sealing parts.
