power mirror wires color! HELP PLEASE!!!!
this is not the case, one is a ground one is right to left movement and one is up and down movement, and thats all there is, however one is green and white, one is green and yellow and the other is just yellow, makes it confusing, cannot find a single instance on the internet that covers these colors so i guess im just gonna try my luck until something happens!
I cannot help you 100%, but you should be able to use the information in the included image as a reference point to get what you need; it is from a '96 european wiring manual. The colors are different, but the function is the same. Perhaps this will give you enough info to run some tests and sort out your wiring. Good luck!
i tried everyway possible actually! none work! so i just hooked up the LEDs and called it a day! none of my dash lights work at all or my cigarette lighter thing since i got my sterio PROFESSIONALLY put in.... LIKE what the LOL. previous owner had done some crazy wiring, im assuming that theres probably just no power going to them just like the rest. GOOD THING i have aftermarket glow gauges so i can still see LOL
