power drop
blue magic
32
Mar 4, 2009
fredericton,
on my way home today while topping 2nd i felt a huge pop and drop in power, checked for leaks and everything looked normal. didnt see anything out of the ordinary. every time i hit 3000 rpms my power just drops like crazy.
everything before the 3000 is fine and normal, is this a fuel pressure sending problem? i did have it at a quarter tank, but after i fueled up it was the same prob, we did just have a huge rainbstorm as well.
any suggestions would be appreciated. thanks, :ohdamn:
hey, good call, that did cross my mind because its usually when the boost takes it and makes more than a 4 banger, it was just a visual check first, never done a boost check before.
just got the car not even two months ago. kinda feels like a boost leak. thanks alot:hellyeah:
Yeah, try that and see what you find. If that doesn't reveal any leaks it might be a good idea to replace the plugs and wires as well as the fuel filter as one of these could give you that type of problem as well. Good luck.:)
helllloooooo, found thank newbie gods. when i squeezed the intake pipe, it almost came off the mani, rehooked it tightened it and now its as good as new if not better. thanks for the tips and replies. :hellyeah::hellyeah::hellyeah:
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
