Post your FP Intake pipe pics
I would post a picture but it does not fit! Im using stock manifold with an hx35 and it hits the shifter cable ends. Iv cut the counter weight off while back but i have no room anyone else have this problem?
I have a tight fitting FP intake as well but that is mostly caused from having to use a 1g head and radiator pipe. Basically my fp pipe touches the Rad hose and pushes it down just slightly making a very small gap between the shift cable ends and the rad hose. This is with a Holset wh1c and TS manifold. So my setup does very a bit from others.
i bought a universal 1.5" flex radiator hose and I have a 7 bolt head with 6 bolt block. my tial 38mm hits my stock radiator I will post picks tomorrow.
no clearance for the intake it would hit it, i was thinking of grinding the first counterweight mount right off but im not sure if that will even solve the problem?
No maf because I decided to go SD. I hope I dont run into any tuning issues on start up.
I have the same problem. I'm thinking once the car is on that it's hitting the cable ends/shifter on trans because it gets hard to shift.
  • Wanted 1g WANTED: Oem stereo
    Looking for a 1g own radio/tape/cd type head unit, prefer with aux input.
    • klipschaudio
  • For sale Autometer oil pressure gauge
    Autometer Z-series 2-1/16" electric oil pressure gauge. Works fine, replaced it with a...
  • For sale 2g 2g 97-99 pass front rocker corner
    2g pass front rocker corner
  • For sale Genuine MHI TDO5 16g Turbocharger
    TD05 16g from my 1g. The turbo our cars should have come with. Great stock appearing upgrade for...
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
