possible water Pump issue
blackgs8690
May 17, 2009
Rochester, New York
hey I'm very new to these forums in fact i just joined today. now, i just bought two eclipse's. one is a five speed rs with a blown engine(crankshaft). and the one that i currently drive is an automatic with a cold air intake(homemade). and i have to put water in it almost every other today. Today it got really bad cause the temp gauge shot up and it started smoking white smoke. Any idea on what the exact problem is?
and is there any special maintenance needed for 420a's
ps i plan on doing lifting the engine out of the auto and putting it in the 5 speed so i would like any helpful engine swap advice
If it's smoking white smoke then you most likely have a blown head gasket. Check and see if your oil/antifreeze are commingling with each other. Also, smell the exhaust and see if it smells sweet. If it does, then you've either got a blown head gasket or a cracked head.
Could be the head gasket. If you've got access to a compression gauge I'd do that right away. If not, a simple spark plug check might show signs of coolant if it's bad enough. Is it running rough at all?
