RallyFan802
- 0
- Jul 30, 2009
burlington,
Vermont
Hi, Im new to this soo bare with me. I just recently purchased a 96 gsx with an auto trans. The car runs good except when you put it in drive you get very limited throttle response till about 40 mph. Now initially I thought it was a problem with the compression or the turbo, however i check the compression and its 160 across the board and I hooked an obd2 scanner to it and no vacuum leak codes. Also when you put the car in reverse it has normal throttle response and shifts very aggressively into that gear. It sounds like a problem with the gears. PLease any input would be helpful. Im starting to pull my hair out... THANX
