420A Pops out of 5th at certain rpm
onefast2gdsm
866
6
Aug 30, 2010
millersburg, Pennsylvania
My 95 gs is popping out of 5th gear as soon as you reach 3200rpms or higher. It will pop out about 5-10 minutes after reaching those rpms, whether you hold it there,raise rpms, or lower rpms. What could cause this?
onefast2gdsm: it is likely you are going to need some service on the trans. How many miles are one the unit?
Good chance its the bearing BUT I would try to check/change the fluid first. Generally pop outs after lots of no problems miles tends to be bearings.
MB
