poping sound
sharky559
191
Mar 6, 2010
Sanger, California
ok so the sound is coming from (wheel) the front left side. the popping starts when i let go of the clutch, mostly when i drive around the city. i took a look at the boot and it looks fine grease is still in side.. what could that be.... need help:confused:
i usually turn hard to left or right from a stop and just as u start to take off it clicks or pops louder than normal i would suspect the cv joint
could be ball joint. Jack your car up and see if there is any side to side play, in and out play, and in and down. In and out would be wheel bearing, side to side could be tie rods, and up and down be ball joint.
im going to jack it up and move the tire around to see if there is any play. will post soon. thanx
