EdwardNorth
- 292
- 1
- Dec 20, 2003
Waterford,
Michigan
Hey all,
For a couple of years now I have been running an EvoIII 16G setup on my Talon. While the performance was improved somewhat over the T-25, the results were minor and not at all what I expected. I have tried quite a few things to bring out the potential of my setup, but thus far have seen no improvements.
My biggest concern and mystery is, setting higher boost makes absolutely NO difference in performance. To clarify, if I have my boost set at 15 psi, the car performs exactly the same as if I set it up to 21+ or anywhere in between. Not a bit of improvement in acceleration or on the butt-dyno whatsoever. I feel that I have the necessary supporting mods to have very nice results at higher boost with this turbo, however I'm just not seeing much.
I have a couple ideas left of what the culprits might be, however I would greatly appreciate your input and suggestions on what to do to get the kind of performance I was expecting. Here is my current setup:
1997 Talon TSi AWD with roughly 21000 miles (yes, it's a very young and healthy car) 5-speed manual
- FP EvoIII 16G turbo ported
- Dejon Tool Super Big SMIC (rated to 400hp)
- FIC 650's
- Walbro 190 (not rewired)
- S-AFCII
- HKS Intake
- 3" downpipe, high-flow cat, and GReddy catback
- Ported exhaust manifold
- Hallman MBC
- Boost and EGT gauges
- Dejon Tool hard lower IC piping
- Hahn Racecraft Stage I upper IC pipe (the section with the BOV)
- GReddy type-S BOV
- AGX adjustable shocks
- Springs and Camber kit
- Short Shift kit
- Datalogger
I think that's about it. From what I have, the only thing I really think might be causing the problem is the SMIC. Dejon says it's rated to 400 HP, but despite all my best efforts I am not getting any better performance. I have logged and tuned with the datalogger and AFCII, and tried many different things to get at least SOME difference in performance at higher boost levels, but I am honestly stumped. Stumped, and pretty disappointed in my results.
The other things I don't have are a complete set of hardpipes, as the 2nd upper IC pipe (from the TB to the BOV pipe) is still the stock rubber-hose, and the intake tube is the stocker as well. Also, I am running the stock clutch and flywheel, but I don't think that is causing the issue.
For an example of the performance I am seeing here -- after nicely tuning the car and posting my timing curve on the forums, verifying that it looked good with other people, I tried timing a 2nd gear pull, punching it at 3500 RPM and going to redline at 7000. It took me almost 5 seconds! This is my result whether I'm running 15-16 psi, or 21-22 psi. The car should be MUCH faster than this.
I usually run 94 octane, but have also tried 100 race gas with the same results.
So I suppose my biggest questions are:
1) Would upgrading this super SMIC to an FMIC make the difference and give me my lost power?
2) Does my current lack of full hard IC piping and hard Intake piping have anything to do with this issue?
3) Is there any chance I have a boost leak somewhere that is robbing me of this power? The boost gauge does seem to indicate perfectly, if it matters.
Thank you for taking the time to read this, and I hope you guys can help me figure out what to do.
- FIC 650's
- S-AFCII
- HKS Intake
- Hallman MBC
- GReddy type-S BOV
- Short Shift kit
- Datalogger
