Pocketlogger- no connection- CEL code checker no connection
GILZTSIAWD
748
11
Feb 4, 2004
petal, Mississippi
I just put a new engine in my car, just another 7-bolt so same motor and all that. Only thing that was different when i went back together with it was that i put a maf-t on it. Now that I have it all back together and everything my pocketlogger is not getting a connection to the ecu and I also have the computer thing to check the check engine codes with on cars and it wont connect either. Before the swap and putting in the maft it all worked fine. Any ideas on why it might not be getting a connection? Some type of fuse or something? My afc is getting a connection fine and i can make adjustments with it and everything. any help would be great :confused:
thanks a ton man, that is EXACTLY the information I was trying to locate!!! :thumb:
note for anyone else that has this problem and stumbles upon this thread, also check the radio fuse in the fuse box under the hood, thats where my problem was.
