Pocket logger whiz needed. Somethings not right?
DJ23GSX
773
6
Feb 22, 2004
W. Springfield, Massachusetts
When i make a pull i always have my pocketlogger in big display mode so i can easily see knock and timing and in big display mode it holds the lowest and peak values below the big numbers. I log rpms knock timing and idc's. Here's my problem when i save a run and i'm in big display mode i see my idc's peak at 98% but when i look at that same log in graph mode and even in PLviewer on my pc i see my idc's peak at 82% Which one is the correct one? I've logged in both graph mod and big display mode and they both get almost identical sample rates so i don't think big display mode would pickup anything the graph wouldn't.
Yes i've searched there and didn't find anything and i am waiting for my membership to be verified so i can post about it there.
Just for the record this is my log when the big display mode showed my idc's at 98% As you can see the highest they reach reach when you look at the same log this way (PLviewer) is 84%.
    • Sdcryan1
