Pockeg logger installation on 1g ECU
alqatan
136
Aug 3, 2004
Bahrain, Jid Al, New York
As I said in my other posts I have two cars with 4g63, the first one is eclipse 97 year model which the pocket logger should work great, my other car is custom project, It's 1993 Mitsubishi colt with 1g ECU+1g wiring.
The problem I don't have that thing I should connect to the 1g cable, how can I connect it manualy like installing S-AFC in the ECU
It has 4 wires I guess but I don't know which wire go to where in the ECU
I believe it has 4 wires, one ground and one power the other two wires I don't know which pin should I connect them too.
Is there anyone can help me with that?
Thanks
What are the wires that connect to that connector that is located in the fuse box?
Here the e-mail betwen me and pocketlogger sells, actually I didn't understand him very well!
Yes, its 3 wires (one is ground). You will need the 1G DSM wiring
diagram.
I'm sure if you ask around, someone can send you a copy of the PDF. You
will need to look for the "DLC connector" and follow the wires back to
theECU.
Regards,
Mike Montalvo
digital tuning, inc.
www.pocketlogger.com
The diagram will tell you. The three wires go to pins 1, 10, and 12 of the
DLC connector in the car. I have no idea what colors they are, but if you
have the diagram, find the DLC connector and it will tell you what goes
where.
Regards,
Mike Montalvo
You need the WIRING DIAGRAM. Not a picture of the ECU connector...that's not
a wiring diagram. The factory service manual has a wiring diagram that
clearly shows what pins on the ECU goes to what pins on the DLC connector.
It is available in PDF from multiple sources and I could not imagine doing
anything like you are doing without one.
