Link G4 Plugin ECU's for 97 Spyder GST?
Tuomas
5
Jun 5, 2019
Norrköping, Europe
I have searched with no luck. Is there a Link ECU that will connect to the original wiring of my 97 Eclipse GST? Or Is there better options?
You will have to go with an Evo 8 link ecu
http://dealers.linkecu.com/EVO8plugin
For this you have to switch a few pins on your edu connectors to match. There are plenty of links.
You can go with Ecm link v3 that is a direct plug in.
The next option would be a stock Evo 8 ecu and tune with evoscan.
This order is most expensive to least expensive.
