Please HELP i am about to kill myself
CFeclipse
264
Jul 10, 2007
San Diego, California
Hi everybody i am having a really bad problem...
I have DSMLINK V3 6 bolt on a 2g 97 gsx
I Turn on my car normal but when a step 100% on the gas the RPM goes down to 0 like a bike !!! i can idle it really slowly but when i step 100% on the gas again to 0 rpm also the lighs on the dashblink..
i took to it to a friend house to check it out and the check engine light start going crazy on.. off
then after like 6 blocks the car turn off... push it like 1 block and turn it on like nothing no check engine nothing and like 20 min later i turn it on and the problem appear again
If i try to run like that it will start throwing explosions like i was having a boost leak or a bad wire.......
I already check CAS....
MAF
Battery
COP and also put regular cables
Any idea\\-
with the car off but on ignition, load up dsmlink and check the tpsvolts and throtpos... make sure its from 0-5v (i think...) and 0-100% respectively? might be something related to that, would def check that first. you can log tpsvolts and throtpos without the car on, so start a log and check it out... if its completely off that might be your culprit.
http://www.ecmtuning.com/wiki/v3tpsadj
