Pistons?
ModRacerDSM
53
Oct 31, 2011
Hanover, Pennsylvania
Iv seen that a lot of people put in wiseco or JE pistons with the CR of 8.8:1. I know this is a good ratio for adding turbos and what not but i was wondering if the 10.5:1 is an equally good ratio or better or worse? Just trying to figure out the differences. (for a 420a which after rebuild im planning on turbo)
10.5:1 your turbo tune, and tune in general will be even more critical to have perfect to keep from pre det.
A general rule of thumb, lower compression for boosted applications, raise for NA. As said above, 10.5 will work with boost, but need a dead on tune. and will need to be careful on how much boost you are running and the like
so safer to go with the 8.8:1 if im planning on turbo
The safer bet is to go with what most people have already done and works. A lot of people have tried to do a lot of things for 16 years so things like this are pretty dialed in. :)
Do some searching, not limited to here. Selecting a compression ratio is pretty basic knowledge when building a motor.
http://lmgtfy.com/?q=how+to+choose+compression+ratio
Additionally, if you are serious about learning, buy a couple books about engine performance and rebuilding.
lmgtfy.com? Thats awesome Dave. :thumb:
I got one...
http://tinyurl.com/43hz2sn
:p just givin you a hard time man.
You will have better bottom end with the 10:1 pistons to make it more streetable when out of boost
Sent from my iPhone using Tapatalk
if you plan on going turbo after, just get 8.8:1 or a 9:1 cr. 10.5, like said above, is going to need a dead on tune. and you won't be able to run as much boost. what type of fuel do you plan on using?
