pistons
Status
Not open for further replies.
motoman358
189
3
Jul 29, 2005
Oak Creek, Wisconsin
who makes the best pistons out of JE, Wiseco, and Ross? i am looking to purchase a set for my car and want to know if one is clearly better than the others or if they are basically the same. any info would be appreciated.
BTW: it is for a 6 bolt and i want to use 8.5:1 comp if that makes a difference. also i want to go with std bore if my block will allow for it, i dont see and damage in the cylinders and the crosshatch is still present.
I couldnt tell you from personal experience yet....but when I was researching...wiseco was the best bang for the buck...so thats what I went with...it also depends on your goals...and how far your going...
i have a bad feeling that if my build goes ok it will never stop, so i want something that will hold lots of power.
ah someone like me...started off as a simple rebuild...next thing i know the 6 bolts going into a 2g and I got hks 272 cams going in.....just spend like an hour in the cylinder head and short block forum reading up on the various pistons...you will pick up alot and be able to make a choice from there....thats what I did.
Status
