piston slap??video
I did not clean them, I figured I didn't have to they were brand new. I pumped them with oilthen drained them and put them in.after I took out the mpi relay and turned the car over a few times for 10 seconds then fired it up, it ran for about 20 minutes then back fired.
Only thing I can think of is I didn't get at the metal shaving out from when the owner before me fried apiston.
Hey I have two Ross. 020 piston, I was thinking of swapping my one blown Manley piston. Has enyone ever tried something like this or is the weight difference to much?
That depends if they are the same CR.
I would have the pistions weight matched tho
Pull the part nimber from the top of the piston, if you do not have it somewhere else.
Then check with one of the supporting vendors! Extream PSI, JNZ or one of the many others and see who can get you one!
Started to pull my head today. Got cover, belts, and pulleys off and noticed my intake cam gear has a little play. Side to side, almost as if the dowel is bent or too small. Will this cause a sound like the video posted? Proceeding with the pull tomorrow.
Cam gear bolt not torqued right?
That tad bit of play will not cause what you have discribed, but needs to be taken care of.
did you see any followers off the HLA/valve tip
Ok...so i pulled the head today. Everything looked very nice. I still plan to port the oil feed. The galley wasnt very deep at all. I took the lifters and rollers out to test the valves. With head upside down and sparkplugs in, i filled the cc's with kerosene. One exhaust valve leaked right away. And 5 min later 2 intake valves leaked. Im not very experienced with valves yet but im certain this would not cause a noise like the op's. I didnt see any damage to the valves so im gonna lap them and see where it goes. Any advice on the grit compound to use bogus?
I agree bogus is the man.I should have my head off tonight and will be posting some pictures .
Finally got the head of in record time , only took about 50 minutes. I broke three valves and put a huge hole in cylinder three. sorry you need to right click on the picture and open in new window, i cant get them to work right. Or you can look at my uploaded pictures.
showimage.php
showimage.php
showimage.php
showimage.php
showimage.php
Dude! Sorry for your loss. Mine actuallly turned out to be a bent valve. The 2 slow leaking exhaust valves lapped up fine. The one fast leaking intake however did not want to come out! No damage to the seat or the guide! Lucky i guess.. it was caused by a siezed or improperly primed lifter from my previous build. When i pulled the vc awhile ago the roller was off of the lifter and valve. The car ran with only 7 intake valves LOL, how? Idk noob mistake and was never discovered until the teardown.
Bogus..
If i buy a new replacement valve will it be a direct lapping and fit? Or will the seat and or valve need to be cut/sized?
