Pinhole on top of radiator. How to fix?
fourgsixthree33
1,244
46
Oct 25, 2010
Athens, Pennsylvania
I have a 1G radiator that I would like to use in my 2G again. I took it out and put the 2G radiator back in because the 1G radiator sprung a small pinhole leak on the top of the radiator.
Since it is plastic, I can't weld it. What can I use to patch it?
I tried JB Weld. It worked for a week or so, then peeled off due to it being plastic and getting hot.
Anything else that could work?
not really because its constantly under pressure then not, under pressure then not. it fluctuates so much so there really isn't a good fix other than a replacement, or an Upgrade :D
jb weld and the permatex stuff is just more of a bandaid or temporary fix though? noone has been running for years using that stuff though right?
The permatex kit is decent. It could last quite a while if applied well. Years and years? Probably not.
The kits and sealants are crap on a high heat radiator tank like this. The only way to seal it up is to actually use a plastic welding setup. It actually uses fillter and melts new plastic to the old. The kit can be bought at harbor freight. It is basically a high temp soldering iron with a flat tip and different filler rods.
IMO, you didn't do good enough prep work for the JB weld to work. A pinhole shouldn't be a problem to fix with JB weld. I had a repaired spot last for over 4 years til I sold the car. JB weld is good to somewhere around 500*. It sticks to plastic just fine with the correct prep work.
You can always drill it out a little bit and screw a SS pan head screw in there and jb weld the threads and over the top of the screw. The screw will hold the pressure and the JB weld will seal the leak.
Sand with 60-80 grit. Sand the top of the screw also. Use a file or something to cut a cross hatch pattern around the area. (not real deep, just 1/32 or so) Clean really well with rubbing alcohol. Let dry completely. Mix up and apply the JB weld and let it sit for 24 hrs. You can even paint it after it cures so it doesn't stick out bad.
The JB Weld I used was also that quck drying stuff, not the main type. Maybe that had something to do with it?
I did not even think to sand the surface before applying it.
I have some regular JB Weld so I will do the prep this time and see what happens.
Great replies with many ideas I didn't think of.
Thanks a lot and I will let you all know how the JB Weld job goes this time around.
quit being a cheap fvck AJ, and just go with an aluminum radiator...
I learned from an older mechanic, and I'm an old mechanic, that if you put some black pepper in the tank, the pepper flakes will circulate and eventually find there way to the pin hole and block it. It's been holding on an old Bronco of mine for 3yrs.
Amazing the stuff you can do with some WD40, duct tape and now black pepperLOL
BK85
BK85
We do this at the track with the Dirt Mods if we have a small hole.
Tried it on a DSM once. BAD idea, made a mess, clogged EVERYTHING up.
Use some rtv silicone and let it dry overnight. Job weld is the best option though. Or you could quit being cheap and just get a new one like you should LOL
Take the radiator to a repair shop. They will fix it permanently for $35-$50 depending on location. They might even replace the top tank.
A radiator repair shop will just replace the tank if it is plastic. They will charge you more than what it cost's to buy a brand new radiator just for the tank and install. The cheapest i have been quoted is around 130 for a new tank and install. you can buy a new radiator from rockauto.com for around 80 bucks.
