1G Pics of Morrison "stock"manifold on car?
enriquez2000
2,411
1,020
Oct 5, 2014
fort collins, Colorado
Im wanting to see pics of the manifold and exhaust set up on Morrisons stock replacement
I notice the flange kicks up in the front which would change the o2 housing angle as well. Im trying to see how a downpipe would still bolt in with no modifications
Not sure I see it, but Matt and Annika will be back on the 4th if you can wait to get all the details.
It looks tilted here but note that on the car the turbo flange is below the exhaust flange so sitting on a table it will tilt, yoou just can't see how much the exhaust flange it also tilted.
I'm confused. The stock manifold is tilted isn't it? Are you suggesting a stock manifold turbo flange is perpendicular to the exhaust flange? I can tell you for sure it isn't and that's why you can't pull a manifold off the car by itself if you're still using an exhaust stud for one of the four bolts. Stock turbo flange is tilted.
Its a stock replacement so will have the same 7° ish angle on the flange to match the blocks angle. From when they released it all the factory parts fit as intended inc o2 housing and DP
It could be my confusion honestly... i have my stock manifold off with turbo bolted to it and it looks "flat"... it could be my eyes
I haven't installed my "Stock Replacement" manifold yet but Matt says that it might sit an additional inch or 2 from the water pipe. I'd have to dig up the email for his exact reply. You can always email Matt - he replies pretty quick.
