Photo's of wiring behind center console
jgoble32
115
Aug 12, 2010
Manhattan, Kansas
Ok so I've done all the searching I can thing of on here and on the web.... I'm trying to see what the wiring behind the center console should look like with the cigarette lighter. The guy before me removed it and put a boost guage there which makes no sense to have there ### while boosting don't really wanna take eyes off road. So I need to see where the correct wires are for a cigarette lighter are so I can hook it up properly. I am having a battery drain which started after I hooked up the new cig lighter. So if you can get a shot of the wires that would help out a lot. Thanks
This is before I got it all finished up, but I had the wires labeled. If you notice there are 4 wires with tags on them (green/white, black/yellow, blue/white, black/white dots). they are as follows:
Green/White - Cigarette lighter bulb (+)
Black/Yellow - Cigarette lighter bulb (-)
Blue/white - Cigarette lighter (+)
Black/white bulb - Cigarette lighter (-)
I bought the car with almost everything in the center console cut, Luckily I have access to AllData at school and was able to pull all of the diagrams to get it fixed. As of today all of my electrical finally works in my car... after about 45 hours of chasing sparks.
Ill get some info for ya after I get back from a parts run. Im finishing up a complete rewire so Ive gotten pretty familiar with just about every single wire in the 2g. Looks like Mezzio is correct on the wire colors but If you need to know where they come from, Id be glad to help out.
Thanks that does help. Well once I clean up this rats nest of wires hopefully I find the ones your talking about.
so here's a pic of the rat's nest that I found and now am working on cleaning up. I noticed that all the speakers are re-wired and the stock wiring was never removed. Joy now to remove them all and found plenty of loose wires that could be causing the short/battery drain. also did rewire the cig lighter according to your help so hopefully that worked.
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
