Permanently mounted datalogger/monitor
stock1g4g63
1,193
Jan 2, 2003
(was TX) Anaheim, CA, California
Hey guys, I was searching but couldn't find any permanently mounted dataloggers/monitoring equipment for the 2G's. I found the scanmaster 3 for the 1st gens, but apparently they aren't available/compatible wit hthe 2g's. Anybody know of any?
Also, what the hell is this and does it really work?
use a laptop or palm for logging, u can take it out wich is nice, all that crap inside mounted gets old. and that is a coil on plug setup, wich you dont need, yes it works, but dont bother.
theyre is no specialized equipment for logging. the specialized equipment is a laptop, or a palm pilot. you could rig up a mini pc and use a 7" lcd screen, but total waste.
thats a coil on plug setup (KOP) works good,only with a msd box. or someother kind in ignition amplifier.
notice the intake manifold?
Defiant said:
That's the motor.
That was funny.
Yoshi, we can use my logger on your set up. You get the data, adjust your AFC, get a little more data, make some finer adjustments, and we're done.
i got a coil on plug set up from sbr and it works real good my idal is grate but so so expensive
