Performed boost leak test, heard popping noise inside valve cover
nestamon99
41
May 10, 2004
Sunriver, Oregon
I will assume that the seal inside the turbo took a crap. When I performed the boost leak test, I removed the hose from the TB and capped opening. Then I pressurized intake system through the turbo inlet and when I did this, a popping noise could be heard from valve cover. The turbo only has 2989 miles on it. How is it possible for a turbo to leak air internally to the exhaust system?? There's absolutely no oil buring
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
