Performance parts
Greedy Pimp
253
4
Mar 27, 2009
Newark, California
I have a couple of nice parts laying around i have no use for.
H1e, same as hx40, un known miles but was rebuilt some time recently because of the stamp on the tag and the exhaust wheel is pretty clean with a red mark on it, normal side to side play was pulled off of 8.7 litter school bus, also have 22cm and 17cm hotside both twin scroll t4, 400
act pp used, 90
lc1 wide band and o2 sensor w/o gauge used, 70
2 used 255 walbro fuel pumps used, 50 for 1
findanza lighten flywheel 18 bolt, will come with new friction pad $60, 140
MHI EVO3 BIG 16g, needs to be rebuilt and new comp cover and comp wheel because it had in and out play which ate the compressor wheel and cover but side to side was normal, turbine touched exhaust cover no damage, turbine shaft is in grate condition, good time to turn it into a 20g, stock wastgate and 14b housing, 190
Complete 1gb combat body kit, 150
3/4 of 1gb drift body kit, rear bumper and side skirts, 90
Any questions pm me or give me a ring at 510 Nine 5 Two - 1 Zero 3 Nine, Travis
Pick up only!
H1e, un known miles but was rebuilt some time in its life normal side to side play was pulled off of 8.7 litter school bus, also have 22cm and 17cm hotside both twin scroll t4, 400
act 2600pp used, 110
lc1 wide band and o2 sensor w/o gauge used, 80
2 used 255 walbro fuel pumps used, 60 for 1
findanza lighten flywheel on my car, will take off in about two weeks, will come with new friction pad, 150
MHI EVO3 BIG 16g, needs to be rebuilt and new comp cover and comp wheel because it had in and out play but side to side was normal, good time to turn it into a 20g, will come with 1 of my ported 7 cm housing, 240
Complete 1gb combat body kit, 160
Pick up only!
So that that turbo need a new comp wheel, a new comp housing, and a rebuild? Does it come with the wg?
It will be around 5 to 10 bucks, just guessing, let me know and it comes without the gauge which is stated in the post, which you can pick up for 70 at extremepsi.com
Yes and it has a new friction surface. It is for a 6 bolt only and u have a 7bolt unless u have a 6 bolt in your 2g then it will work.
Helluvadsm, 45 bucks and its urs.
Hope you don't mind if i post up here instead of making a thread.
Help me clean my storage/garage!
Selling a set of tires came off my gsx rims. 3 matching 1 not matching still have plenty of thread on them.
Hks SSQV bov with 1G flange
1G Bov
Delta 272/272 cams regrinds
1G throttle body freshly rebuilt with mil.spec shaft seals
Arp head studs torqued twice or three times lost track
2G intake manifold.
Pm me if you are interested In anything.
