PCV Valve or Vacuum Pump system
missionx96x
136
Jan 30, 2006
Jackson, New Jersey
which should i do? As of right now i removed the pcv valve and tapped a fitting into the valve cover. so if i want to go back to pcv i would have to get that valve to fit back into the valve cover or buy another valve cover. however a vacuum pump would be over 100 bucks. is the vacuum pump system better than the stock pcv setup?
A vacuum pump system would be a lot lot more then $100 buck's. Do a search we just had a good thread on this.
