Midnightride
- 183
- 0
- Oct 4, 2006
Columbus,
Ohio
Let me explain first, then I will ask my question. Not to long ago I unhooked all the vacum lines from the throttle body, removed all sensors and what not for emission in engine compartment. I also got a fuel filter and routed the PCV and the breather line into the filter and then hooked it up to the intake snorkel. I then developed a leak on the cam seals so we took the filter of an relized it was bit to hard to blow through. (did replace the cam seals, and hope no other seals were ruined by the pressure build up)
So now I have one hose coming of the PCV and one hose coming from the breather side and have them T into a hose going to the intake snorkel like stock.
Question I have, will it still realase the pressure and will there be enouph vacum to get the pressure out by this method or should I just hook the PCV back up like stock and keep chaning it every few months since they seem to go out. Do I need a filter there(catch can, or filter)? I know I will be gettin some oil int the turbo, but it does that in stock from too so should be to bad. I can put a filter in there, but the ones I have had so far have all been to restrictive. I got one that was pretty free flowing, but somehow condensation go in there. We blwe through it and water came out so no good there.
Question two, having it hooked up like I do, could this make the oil dip stick pop out as well? I have never had it pop out as long as I had the car and for some reason yesterday morning upon start up it poped out. Well atleas I think it was during start up and letting the car idle cause after work I noticed it had oil everywhere and dip stick was half way out. Like I said its never done that before. I was not boosting at all just normal driving especially during the weather conditions. Actually driving slower.
Just thought I would ask. Perhaps they are related, or perhaps not.
