Bottle Cap Sucked into intake
97GSTJake
64
Mar 3, 2006
North Vernon, Indiana
I was just curious what ALL can happen if you are venting your bov and the intake hole from the recirc. pipe is clogged with a bottle cap, and the bottle cap gets sucked into the intake? What all can happen if this takes place? Will the engine die or the turbo? Would it burn the cap off from the high temperatures?
Why would you re-post this WTF ? You are getting tons of help on the other thread.
well i was just hoping for another post on the other one but it seems to have died off... tats why i posted on here
WTF WTF ? what do you want people to say? everyone said your fine and if your car runs normal your ok. Do you want me to say your pistons now going to fly throgh your head and take your cam with it :tease: ? You got your answer several times over.:confused:
Ok look, Ill buy your car from you for a hundred bucks and you dont have to worry about that bottle cap anymore. Heck I might even give you my n/t turbo when its done.
:talon: LMFAO...Ill give you 102.00 and give you a 94 talon DL LOL...honestly why was it so rigged up that you were using a bottle cap as a plug? GO BUY THE PLUG!!:tease: IT'S LIKE 2 bucks! hahahaha:talon:
i just got done reading your other post about the SAME topic...b/c the looks of it, it just rattled its way out...it wouldnt make sense that it would get sucked in b/c if you had it jammed into the hole and you couldnt push it any farther then the intake would have no chance of sucking it in, also you would have heard some bad sounds. there is nothing wrong with your car its fine.
