MaxGdsm
- 128
- 1
- Apr 12, 2007
bellingham,
Washington
I have a 64bit Vista OS and Ide like to hook my laptop up to data log, maybe with plans in the future to get the ECM tuning software but that is a ways from now.
In addition i have a JAW wideband hooked up i can log with RPM with a USb serial adapter product similar to this.
USB 2.0 Serial RS-232 DB-9 MINI Adapter with Detachable Extension Cable FTDI CHIP 765288 LOW PRICE $16.79
Ide like to at the very least be able to hook up to my ECU and data log whatever info is available. I really want to log AFR with other parameters if possible as I have an evo3 turbo with other minor mods and want to see what boost levels are safe with my setup instead of just trusting random people and their unproven claims that 15psi is safe.
Is it possible to do this without buying cables and a palmpc?
I have several 9pin Serial cables so I was going to try this method below.
http://www.dsmtuners.com/forums/art...03316-how-set-up-mmcd-make-logging-cable.html
But then what datalogging program should I use with a 64bit vista pc?
Basically I am new to this, have done a bit of research and have found what I am doing is not the main stream and want to know if it is possible and if so how.
Any help would be greatly appreciated as I am anxious to get this started.
Below are other links ive looked at.
http://www.dsmtuners.com/forums/tun...3009-how-make-your-own-data-logger-cable.html
http://www.dsmtuners.com/forums/tun...stion-anyone-using-logger-vista-computer.html
DSM datalogging software - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
