Payed Tuned with Holset only 303hp?!?
Something tells me this was not tuned on a dyno, at least not by shop persons. My guess is, tuned on the street by a friend of a friend that knows somebody that knows how to tune...
I'd find Ligo if you're in DFW. He will tune it right... but he won't like it much if you bring him a vehicle that is not ready to be tuned.
Sounds like you did'nt setup your laptop to log correctly. You have to put in a little effort as well. How much hp did you expect on the HX-35 .55 a/r combo?
500awhp has been made
On the hx35 .55
Ar bep, 600awhp has been made with the hx40 in the .55 bep as well. I'm shooting for 600 with my hx40
On the hx35 .55
yep, easily, I've already broken 500 (and the tranny at the same time) on my 68mm 8 blade, and that's only at 31psi and 17* timing let loose at 6500 or the reading might hav ebeen more... the difference between 27/28psi with 15* and 31'sih with 17* was almost 40hp, the holsets don't get efficient until they are in the 30psi + range... and when i run mine at like 22-24psi, My car feels dog ass slow cause the compressor just can't moce air at those low levels
they like high psi like they run on diesels
shit, better stack up on the magnus head studs :)
haha got em, , i stretched plain ARP's a couple months back when i blew two HG's in less than 2-3 weeks :D
read mnore of the postson page 1 and i wouldn't go back to that guy EVER and if i did it would be for a refund only..
if it was alamo, well i can only laugh as they use to be the haltech USA support and distributor, but they were so crappy i was taking emails to help as well as calls since im' a dealer and use to be in daily contact with haltech in austrailia and puerto rico. hal;tech stopped using them fastand now we have a nice shop as "haltech usa" on ht eeast coast
I have normal arp 2000 head studs and i don't think they will hold over 32 psi. I need to get the magnus studs before i blow a hg the felpro permatorque mls has been doing nicely so far at 27psi on the 6152 but that turbo is long gone and i need to be set for 40 psi, good thing is magnus is gonna be 45 min drive from where I'm going to be going to school, in oakville ontario for welding techniques :)
Do the magnus head studs drop in, in place of the arps? I have a 6 bolt block 7 bolt head, and they were both machines to accept the arp2000s if i can take the arps out with out having to change the head
Gasket or take anything off.... Then i wanna do that. I don't think i can though.
it's not so much "psi" as it is airlfow... my felpro and ARP 2000's held over 30psi on 16gand on 57 trim (both by accident but for a full gear pull at least on each (maybe a few more times tilli noticed it was burying the gauge this was years ago)
now i've popped HG's and stretched ARP 2k's on the holset, I think it's a combo of airflow past the 50lb/min and the pressure you make of it with timing, as well as how many times you've taken the ARP's out and put them backin.
I now have the l19/H11 set and i'm still on felpro composite and blew m,y trans as mentioned before at 31'ish psi and and 522hp, when i was lifting the head at a tad less boost on ARPs' 2k's
EDIT: YES,when i put the last HG on my car all i had was the bad ARPs, then i rode motorcycle to a guys place about an hour and something from here bought a new set he had (traded my old MSD DIS-II for them since i was sellingit for the price to buy some and no takers on here), I just pulled one ARP 2k at a time, placed the H11's in and torqued one at a time and been happily boosting the hell out of my felpro composite 28 dollar gasket since, also they don't have directions with them but i have a .pdf on my computerfromthem listing that 6 bolt ones goto IIRC 100 ft/lbs, not 120 or the other style 80 as i often read on herem and the info i have is FROM ARP, the 7 bolt ones torque to 90 or 85 though IIRC but they have less torque because of smaller diameter. I would also say uy the H11's becuse instead of being flat where they can't be tightened or need turned back 1/2 turn before torquiing, they have a narrow point toallow you to bottom them safely without damaging the blocks threads
i was flowing 54 lb a min on my other turbo at 27 psi no problems that i could see. the arps have only been torqued once and never removed. i think id go magnus because they are raited to 90+ PSI :cool:with the hx40 i plan to be seeing the full 70lb a min
Edit: so you were able to drop the L19s in with the head on with no problems?
Since it hasn't been mentioned have your friend check his oil an make sure it isn't contaminated with gas. Last thing you want is a bad tune and washed out bearings. On another note you and your friend should put two heads together and check out the tutorials of how to tune ecmlink yourself. Chances are tuning it yourself just based on that would have gotten you further.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
