passenger window and door
eclipsemustang
110
Nov 15, 2005
suburbs, Minnesota
Recently my power locks on my passenger door went out and then a few months later my passenger window stopped working. its only happeing to the passenger side locks and window work fine on the drivers side does anyone know if this is a short or if the motor just died any help would be useful thanks
Check the wiring harness that plugs into the car body up by the door hinges. The rubber boot will need to be pulled back to expose the plug. If that does not work, try pulling the door panel and check the wiring harness connection for the power lock and window switches.
