parts list amost complete please confirm
mustracetsi
214
18
Apr 14, 2012
bergen county, New Jersey
ok guys i been on search and hunt for parts. i have a 97 talon tsi with a 14b or 16g just looking to go 15psi smoothly on my daily driver for now. so heres what i just pick up and some parts on the way. front ic and piping, denso 750cc injectors, came on some luck local dsm guy was parting out his car and i got 95 eprom ecu socketed and with dsmlink v2 with laptop. hks bov. i think im almost done if yous can confirm. if im correct i just need to get fpr and walbaro 250 fuel pump. note: i now the guy had a six bolt with cams and evo 16g turbo and so on. so i think i can plug the ecu right up. as long as i swap the wires and something on the ecu cause the car with run way to rich. can i just reset the fuel trim. o sorry forgot also need wide band too.
Your going to want a bigger exhaust and atleast port the o2 housing for that 16g so you dont get creep. As far as setting up link there is a ton of stuff already on here for that but super simple i would also get a 1g throttle body just me tho
If you putting in a 255lph walbro get a STM rewire kit for it too.
You got a mbc?
Wideband, boost gauge, I would port yoir o2 or get an aftermarket one or if you feel like it get the PR o2 housing with tial external wastegate but you will have to midify your turbo for external gate the pr is expensive but you wont have boost creep.
Otherwise you look to be going good.
What hp you looking to run?
Also assuming you done your maintenance, no boost leaks good compression etc..
