Spyder P0505 code
2G Josh
115
3
Aug 23, 2014
Bloomington, Illinois
I got this code a few months ago after my car was idleing for about ten minutes. Replaces the IAC valve and the code went away. This morning after getting to work it was ideling for about 15 minutes and the CEL came on with the same code.
My question is what can cause this problem? I never adjusted the biss because I read so many different things on how to adjust it and I got intimidated at the thought of screwing something up.
I'm going to rebuild the engine soon because I have high miles and valve stem seals going bad. Can valve stem seals cause the IAC valve to go bad? When idleing in park or when the AC is on the idle drops down like 150 rpms and jumps back to normal for just a second but tdoes it every 20 seconds or so and idk if that related or not.
Can anyone shed some light on whats going on?
Well its probably he IAC if you're getting a CEL for faulty IAC, and it sounds like its bad.
Did you test the coils? If they test good pull the IAC, keep it plugged in and set it on the TB elbow. Then turn the key to ON and you should see the pintle extend and retract when you turn the key off.What did you replace the original with? Another used one? I went through 3 tan IACs before I just got the black revised IAC from a stealth. Or you can shell out $68 and get a Standard AC99 or AC146 from rock auto (although I got one that was DOA)
Whatever you do don't buy a cheapo off eBay. You wanna take care of that ASAP before you fry your ECU!
