P/S Rack Question
97 Talon Esi
76
Sep 20, 2009
Syracuse, New York
I have a pretty major power steering leak on my car. I Put it up on the lift at work and noticed it was coming from the boot where the inner tie rod goes into the rack. So I pulled the Boot off and was soaked with power steering fluid which sucked. But my Question is if i can get around replacing the whole rack and just go to the parts store and buy the seal where that inner tie rod goes and if i can what would be the technical name for it so i can call around a get a price. Thanks Alot for Your Time...
thanks I am going to look on google and see if i cant find something on there. I have a feeling that it is going to come in a kit which means that im going to have to remove the rack anyways so i might just replace the whole thing if all else fails.Thanks for the fast reply.
I rebuilt my rack with a rebuild/reseal kit I got from Rockauto. It's like $65-70. I think the non turbos use the same rack but you'd have to check on there to make sure. I don't know if it's something you can do without removing the rack, probably not. I have a tech article out there on my rebuild if you want to check that out.
The Power Steering Rack Is Located Directly Behind The Motor Under Neath. The Easiest Way to Find It If You are still having problems is to follow one of your tie rods up and it goes directly into the rack.
im removing my powersteering and will like to know what i need to do to remove it sucssefully i think i know what to do but i think im missing a few steps can someone if possible help me out thanks just let me know step by step if you can ill appreciate it...
i just need to know on the rack with lines are the powersteering lines that way i can loop the right lines thanks
  • Wanted 6 bolt NT water pipe
    • chrisman287
