Urgent Question :P
alexrc
62
Sep 23, 2007
Santo Domingo, Central America
ROFLNewbie has a question ~! And urgent one , When push the key to ignition the rpm gauge and the spedotmer goes over 60 and the rpm to 3,000 I start the car and stays like that ! And the battery light comes up on the dash! Need help ASAP :notgood:
:dsm:
That's the theory but I unplug the line of the alternator and still , both cable on the alternator , and still having issue ,
I rested the ecu like 10 times and still , and I have good ground on the car,~ @#! I don't know what else to check , ! everything is in order ! any more ideas ?
Newbie has a question ~! And urgent one , When push the key to ignition the rpm gauge and the spedotmer goes over 60 and the rpm to 3,000 I start the car and stays like that ! And the battery light comes up on the dash! Need help ASAP :rocks:
:dsm:
Check you battery..Clean the terminals a check terminal connections a bad ground can do funny things to a car...
Check your EGR Tube and or connections, make sure Its not touching any wires.
My whole car shut down on the freeway doing about 70mph in the fastlane in rush hour traffic. NOT FUN
Ok I found one 12v touching the chassis , it was the remote for the radio , but the speedometer is still at 60 km :p ajaj im still looking for a other cable , that is doing the short , !
  • Wanted 6 bolt NT water pipe
    • chrisman287
