Overboosting
Assuming you've done all proper maintenance, have no boost leaks, not hitting fuel cut etc, it will be fine.
You will probably run Lean, because at the same psi, The 16G will produce more cfm than the stock turbo. You should look into getting a larger fuel pump, Air intake, and exhaust if you want to get the most out of 15PSI.
You need a fuel pump, some kind of tuning tool and a data logger to add to your setup.
How else are you controlling those injectors? And with the stock pump, you are starving your motor.
Isn't awesome how you get 4 different responses from people that probably don't know what they are talking about.
Turn the boost down until you can get a datalogger end of story.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
