options/opinions for gs-t build
97Boosted
188
Aug 23, 2008
Charleston, South Carolina
i just bought a 1997 GS-T that has a spun bearing which screwed the short block so a new one is needed. i purchased the car for $1900 from a neighbor. exterior is VERY clean engine bay also clean as shown in pic. the mods are listed in profile-good deal? i am now faced with the question of reg shortblock or built/bored and what brand.? im also a super noob soo i was wanting opinions on what would be best for my setup also im not looking to make the fastest dsm just something that will be decent on the street :sneaky:
thanks john
edit: i will be towing the car home once i get off work and will post pics and keep udating the build but will be relatively slow since im only 17 and full time student
You will want an LSD in the transmission.
B16G or even a 50 trim.
Wally 255 High Pressure
780+ cc/min Injectors
Fuel Pump Rewire
Front Mount IC
DSMLink
Upgraded breaks
Fuel Pressure Regulator
A lot stronger clutch [CF Dual Friction in my oppinion]
Heres the most common build ppl do, its a 2g head with a 6 bolt bottom end
(able to handle 600hp+)
Block
.020 Over Ross 8.3:1 $430
Eagle H-beam Rods $309
ARP Headstuds $99
ARP Mains $59
Cometic MLS Headgasket $79
Clevite 77 Aluminum Rod Bearings $21
Clevite 77 Tri-Metal Main Bearings $33
Machine Work
.020 Bore
Hot tank
Deck
Freeze plugs
Fuel Pump Rewire
Front Mount IC
DSMLink
Upgraded breaks
it has LSD, fuel system, i have a big 16g on and a t3/t4 turbo. and for the most part yes this will be a budget build. although i want decent power...enough to be quick in the streets
thanks for the input now im just researching the sht out of the major shortblock companies
  • Wanted 6 bolt NT water pipe
    • chrisman287
