Opinions on Upgrade Path for a 1G
BossGVR4
Feb 28, 2005
Fairfax, Virginia
Hey guys,
After getting out of DSMs for a while (I had 2 GVR4s) I came across a 92 GSX for $750 that I couldn't pass up. Right now the car has this in it .....
6 bolt rebuild
- 2g pistons on 1G rods
- Balance Shafts removed
- Cyclone INtake (being removed to re-install A/C)
- Frankenstein Jr. 19C (blows smoke and screeches like a banshee on boost)
ACT2600 w/ Exedy clutch disc
AGX Adj. Front Struts
GAB Gymkhana Adj. Rear Shocks
Step 1 of the buildup
1) Big 16G
2) FMIC and hardpiping
3) 1G Manifold and A/C reinstalled (Cyclone removed)
4) Denso Supra "990" Fuel Pump and Rewire
5) Front Big Brake Conversion
6) 2.5" Turboback Exhaust
7) TurboXS Manual Boost Controller
8) HK$ Type 1 Turbo Timer
9) Autometer Boost, Oil Pressure, Voltmeter gauges
I'm only going ot run 14psi on this set-up and NO RACING until Step 2. My question is should I do the 2G MAS upgrade now or wait till I get the DSMLink ?
Step 2 Upgrades
10) DSMLink for 1G on Palm or Custom Built Pentium P4 Carputer
11) Denso 660 "bluetop" Injectors
12) Water Injection
Any suggestions would be GREATLY appreciated.
DaveC
Looks like fun to me, Wondering why you don't just go with a 3" exhaust and I'm not seeing a AFPR, I would just wait to do the 2g MAF install to your gettin the DSMlink
The reason is I already have all the stuff I listed in Step 1 (and the 660's in Step 2) !
I kinda thought I should wait to do the injectors/2G MAF/Fuel Pump ... and I'll add an AFPR to step 2 as well.
Thanks.
DaveC
