Open and closed loop
bkrathwohl
349
479
Nov 9, 2008
Mt. Pleasant, Michigan
Long story short bought a 2g awd shell swapped my 1g motor in and did a first start today.
A buddy and myself were using link v2 and logged my first start. It is idle surging, which I will need to fix, but it is also switching between open and closed loop every couple of seconds. I was wondering if any of you have ever dealt with this issue before?
Im just trying to get it back on the road so any help is appreciated!
It is looking like the idle surge is what is causing the switch between open and closed loop. Time to fix some air leaks!
It actually ended up being that the throttle cable was not allowing the throttle plate to fully close.
