Only Running On 2cyl "1&4"
Dans91Tsi
60
Nov 29, 2002
Washington
Alright So Im on the freeway when all of a sudden bam, car runs like sh!t. So I went home, disconncted the car and started it to make sure it wasnt plugged or any thing, it was fine, So then I checked timing, it was fine, It didnt jump a tooth or anything and lined up with a test light. So I started the car and started disconnecting plug wires to see if all cylinders were firing. 2 & 3 are not. 2 & 3 are bolth run off the same coil so I checked the coil and is's all good. So my question is, what the hell could it be. Plugs and Plug Wires are new.
Thx
You actually checked to see if the there was spark coming from cyls 2 and 3 on the coil pack while cranking the motor using an ignition tester? What did you do to check the coils? Any CELs?
Yah I did all that stuff I found out it was the eginiton module, power transistor.
Thanks for imput
Dan
