Only Low Horn Works?
jwahl16
427
3
Oct 26, 2009
Havertown, Pennsylvania
I read that there are two horns in our cars, one under each headlight. It seems only my low horn is working (sounds like a dull foghorn). So if i were to upgrade this horn to something audible, which horn would i replace? (driver's side or passenger side)
Also, if only one of the horns work does that mean the high horn needs to be replaced or could it be in the wiring somewhere?
Thanks all!
Thanks all!
You've been mis-informed because there is only one horn and it sits behind the driver side headlight, it looks like a black snail.
:dsm:
There is another one up by the battery. I don't know if it works with the button on the steering wheel, or if it's just for the alarm maybe. I removed that small one by the battery and my horn sounds fine.
OP, maybe yours is just dying.
check the wires and plug and make sure its plugged in properly to sensor. if is trace wires make sure there is connection all the way...if all that is good, get a new horn
Ok, well it seems i am going to head to pepboys this weekend and pick up a horn that looks as close to stock as possible. Do i need to remove my bumper in order to get at the horn mounting bracket? It seemed to be pressed right up against it.
Suby owners wire these bad boys in out here in socal, I think its more for looks because they do it behind the front grill but they are loud!
HELLA Supertone Horns
:dsm:
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
