v8s_are_slow
- 2,824
- 280
- Sep 30, 2002
Panama City,
Florida
okay, for the past 3 or 4 months i've had problems with the dang clutch. disengagement problems mostly. the last clutch i put in was an ACT street disc. and the hub sheared right outta the middle (literally) after only 50 highway miles.
well, i just got rid of the whole ACT setup and went with a stage 2 eClutchmasters pressure plate and 6 puck disc. i've replaced the clutch line with a braided one, new master cylinder (and then replaced it again just to be sure), new flywheel, new clutch fork, new pivot ball, new slave cylinder, and even replaced the whole pedal assembly cause i found out the other one was worn slap out and welding it didn't work. i dunno what else i need to replace (kinda running outta things to change ya know?).
anyway, here's the deal. i just got it goin last night and everything was workin fine. i threw in my GT-13 turbo as well so figured it'd be a good day for a test drive and tune. 1st half of the day was fine. then for some reason the pedal was adjusting higher up off the floor. then the next time i press it, it's to the floor again. went off and on like this all day. thinkin MAYBE it needs to be bled. i dunno. my starter just went out on my way home as well. won't engage it the flywheel at all. so i had to push start it. on my way home, if i pressed in the clutch, it would squeel like LOUD!!!! so just rev matched the gears the rest of the way home. almost like something is rubbing that isn't suppose to be. fingers on the pressure plate hitting the clutch disc maybe? and anything above 60 i'd hear a howling noise. if i let off the gas it would go away. hmmmmm......
i have the correct stepheight and all so i dunno. and sometimes during the day if i was at a low rpm the car would vibrate some. if i pressed in on the clutch or up the rpm's it would go away. but it was off and on like that all day. i don't have a clue what's going on with the dang thing but it's been 3 months or so that i've been dealing with this problem and i'm sick of it. any ideas from anyone would be very much appreciated. thanks!
scott
scott
